Recommended cases <£100
24 May 2012
Im looking for a case for my new build
I have decided to spend no more than £100 and thats an absolute limit, if theres a cheaper one thats a good pick then i would happily go for that.
My old case was cramped and had poor airflow, i will have one hdd one sdd and a DVD/RW. As im a noobie i would ideally like something thats got plenty of room for cable management to make it as easy as possible for myself.
I will have a HD7850 and plan to possibly crossfire them at a later date.
Any ideas? :confused:
Thanks :D
It all really depends on personal preference, we don't know what style of case you like and usually that's more important than just plain price alone.
Lian-Li cases are very high quality but don't expect lots of space in one for under 100.
Some nice choices there, well I've been thinking o maybe going with a black/blue theme as a lot of cases have the blue LED fans, coupled with my black/blue mobo, blue ram, also could purchase a blue CPU fan I have seen.
However I also like the white cases :p
Depending on how you want it to look...
Stretch the budget by £9 and get a CM Storm Trooper - fantastic case.
Or, another great case. Silverstone RV03 is within the budget :)
As someone said above, Lian Li are lovely cases build wise, but you won't get much out of them quality wise. The 500R and CM 690II are great cases for a white build, and are perfectly fine. But they are just that.. Fine..
kd
It's pretty quite at low setting with the stock fans (140mm exhaust 200mm exhauts 2 x 120mm intake.) Upping the fans to high gives no real change in temps just faster airflow really.
Most of these nicer cases are white or black/red fan LEDs. So maybe I'll go with all black ram and maybe a nice red CPU cooler, if I can find one. Troopers got some nice reviews.
Anyone used any of the Antec 902 or 1200s?
