- 6 Sep 2005
Hi guys
I've been really happy with this AMD chip for a long time and with just the stock cooler (saved a lot of pennies in the initial build), but I'm looking to do some HD 1080p encoding for the first time on this chip and I've noticed that is getting really hot 80oC+ so I'm thinking of an aftermarket cooling solution.
I would like:
Either...
Something air cooled that doesn't take up too much room. I've had huge Phantex air coolers before now, I couldn't get my fingers around the case with one of those, but I have upgraded the case since.
Or...
A sealed water cooling unit, I've used the Corsair H50 and H110i before now and been happy with them.
No
I don't want a DIY water solution. I'd bungle it and fry the computer, or myself. Something simple is what I need.
Case
It's going into a Coolermaster Cosmos II case, so space shouldn't be an issue.
Budget
I know what I need isn't going to be cheap and I'd rather buy something really good once that's exceptionally quiet, rather than buying cheaper and upgrading fans etc., later...whatever is recommend really that fits the specs. Having said that, certainly less than £200, less than £170 is even better.
I've been looking round online and much of the info is either from affiliate sites so who knows if it's accurate, or quite out of date now.
Any recommended solutions I can pick up from OCUK would be much appreciated!
Thanks.
I would like:
Either...
Or...
No
Case
Budget
Thanks.
