Recommended current progamming environment for old school coder
str
str
18 Oct 2002
Recommended current programming environment for old school coder
I used to be a programmer back in the day (about 7 years ago), mostly financial or company related databases using Clipper. I've also done some C coding and a small amount of C++/MFC coding but I can pick up just about any language if it will suit my needs given a detailed book about it.
An example of one of my last projects was I wrote the original USBHz program. It was a device driver and it hooked into the USB driver stack to manipulate the polling rate of the mouse.
When I look around I can't decide what to choose as a programming environment.
I've considered the following in order of preference:
Java
C++/CLI with .NET Framework
C#
Visual Basic
C++/MFC (being phased out?)
Most of the projects I plan on doing will be database driven likely with PostgreSQL (will contain millions of records) but I'll also be doing some low level Windows coding for a Spy++ style feature in one of the programs so will need access to the Windows API.
Anyone know of online tutorials or a book for one of the above for getting me setup and running with an environment suitable to my needs?
I've been thinking C++/CLI with .NET Framework (using managed code) but I'll basically be a beginner with a TON of knowledge to accumulate so perhaps I'd be better off with Java or C# as those languages are just as powerful these days and yet they won't require as much of a learning curve and I can be up and running a lot quicker with less knowledge required to get stuck in with my projects?
Any advice or recommendations much appreciated!
If you're considering Java (and Visual Basic .NET), I'd say also consider C#. It will be very similar architecture to C++ on .NET, and practically identical to VB.NET (yet a lot less verbose :)).
I think it would be a mistake to start using the .NET Framework from C++/CLI before having a working knowledge of it in its natural environment (Fully managed, probably via C#).
You only want to step in to C++/CLI in parts of your application where you must use native code for some reason, and then step back out to your more elegant C# land.
C++/CLI fulfils its purpose as a glue language really well, but if conditions allow then you should just ignore it completely (and most people do!).
C# is better than Java as long as the obvious Microsoft bias isn't a problem.
A vote for Python here. It's an incredibly powerful, high level OOP scripting language.
You can do all the win32 stuff you need also.
