In process of building rig in my sig below.
Have a query on ideal fan setup for TJ09. Already have a bunch of 800rpm and 1200rpm Noctuas left over from my last build so trying to decide how to spread these around.
First off - not bothering with a Rheobus. Just want the fans to run quiet (not silent) with decent airflow. Case is afterall going to be under a table and not going to be messing around with it. I also heard the sidepanels can rattle at 5v with some fans, so that's another reason not to mess with a rheobus.
- Anyway, should I leave the 2 stock fans as is ? They are the 2 most vital fans for cooling so if I was going to replace them it would be with 2x1200rpm Noctuas...nothing any louder. Are the stock fans which are also 1200rpm good enough not to bother with the Noctuas ? I ask cause the GPU fan looks a pain to remove.
- For the hard drive fan, and 2 tops fans, since these areas are probably the most noticeable for noise, I am planning to use 800rpm Noctuas. Top fans blowing in or out ? Is an 800rpm Noctua good enough to cool 2 raptors and 1 1tb hitachi ? Should I use the 1200rpm Noctua instead. And how should I spread the drives out - 2 raptors in the bottom bay so they get airflow first, and Hitchi in top bay or all 3 on bottom ?
- Are 60cm or longer sata cables needed if using bottom HD bay ? Same with opticals in top 2 bays ? Will I need 60cm cables or greater.
thanks
thanks
sold it and bought an Akasa Eclipse 62.......
and now living the dream.
Now on my 2nd Akasa Eclipse 62, both cases have had no vibration issues at all...
