- 23 Apr 2007
- Cardiff-ish, Wales
Hello all,
I'm looking for recommendations for "must have" utilities, or certainly ones that you think are worth trying.
I'm currently using:
Ashampoo Winoptimizer 2019, free version that seems okay. Does some benchmarking as well which is nice.
I've also got CC Cleaner free demo that seems to do similar things.
IObit Software Updater, again free version. I like the idea of something that will scan my programmes and check if I need to update. The problem with the free version is that I can only do a small amount at a time. I think I can get the full version for about £8.
Avast Free Antivirus
CPU-Z - great little program that gives a lot of PC info.
Do you recommend anything? I don't mind paying one off fees as long as it's not too expensive, if you think it's worth investing in. I'm not so keen on annual fees though...
Cheers,
Jed
Cheers,
Jed
