- 5 Apr 2021
So this is my first ever post concerning PC building so please go easy
My build started by a Gumtree steal (all other Buy, Sell sites available) with a purchase of a Cooler Master HAF 932. With so much room with the size of it ((W)230 x (H)545 x (D)575 mm), it has been a brilliant introduction for me to look at all the possibilities and test all sorts of bits and even managed to get the 4-way fan temperature and control front panel working. Future plan is to possibly look at SLI/Crossfire but for now I'm looking to finish off my current setup with a case to fit on the desk and off the floor.
Anyway down to business. My current build so far is more akin to a mATX case setup as follows:
Motherboard: ASUS Prime B450M-A II
CPU: AMD Ryzen 5 2600X Six-Core Processor
RAM: Adata 3200 16GB
GPU: NVIDIA GeForce GTX 1050 Ti (intention is to upgrade to 1660 Super with the current graphics card issue I'm just waiting for the appropriate time)
Storage: Crucial MX500 250GB (looking it to a M.2 which I have got down to ADATA XPS Spectrum 500GB)
Peripherals: ROG Strix Scope RX Keyboard, ROG Keris Mouse, ASUS 27" Monitor.
I can not take the credit for the motherboard, CPU+Fan and RAM installation as I used a pre-built bundle purchase but I am getting to the point where I would like to replace the CPU fan so I will have to just grit the teeth and go for it. The system as it is works is excellent for the games I play so not that bothered with that aspect.
I would love to purchase all ROG Strix as I am slowly collecting but I'm not willing push the marriage
. The cases are set more around e/ATX or ATX and I'm not into TUF so no go there.
So my requirements for a new mATX and my 2 weeks study findings and exhaustive searching:
Ideally a case with a couple pre-installed fans that I can then purchase a couple more or maybe a case with no fans installed at all and I purchase a hub and fans to be compatible with AURA Sync.
Thanks for reading.
- Budget: This depends if the right fans come with the case etc but £100 may stretch a bit more!!! Remember the Marriage!!!
- Depth and Height of around 400mm. The Corsair 280X was an option as I am not bothered too much by the width and like the double chamber design but a bit expensive.
- Do I go for branded aka Cooler Master, Corsair, In Win, Fractal Design etc or are the cases like CiT, Aerocool, GameMax good cases. My studies show that they are okay and you pay what you get but are full of plastic where you would expect metal at least. For £30-40 some of them look a little to cheap and concentrate on the flashing lights than the stress and temperatures the case will be under.
- Before I completely disown the flashy lights part I would like to get the most out of the AURA Sync header on the motherboard. Aura Sync currently works with my GPU, Keyboard, Mouse and current Bitfenix fan I have installed in the beast case. The fan was a fluke that it was compatible with my board but makes me what to at least add fans with the capability.
Thanks for reading.
