Recommended me
29 May 2012
Dorset
Starting to get some random hard power offs while gaming although its fine under low load but im throwing blame at my 2011 1250w OCZ PSU
Current rig in sig but would like to future prrof a little, there might be a 9800x3d chip on the horrizon
What are you suggestions?
1200W PSU seems a little overkill, unless you are planning on also adding a 600w 5090 or future monster.
ATX3.x power supplies over 450W AND with a 12VHPWR/2x6 are designed to handle the transient power spikes of modern GPU's, up to 2x the 12V rated output.
Which should sort the issue your're having from your older standard/spec PSU.
No harm in going bigger for peace of mind tho, and I guess the pricing isn't too different.
