Recommended memory card for phone s20fe?
Caporegime
13 Jan 2010
Llaneirwg
Rocking an old 32gb something memory card and it's caused pics to be saved to phone memory. Which is now also full.
For a camera such as this what is a recommended memory card?
Uhs-1?
3?
Any help would be appreciated
UHS-3 as it's the write speed, so how fast the photo/video can save onto the SD card. Ideally you want an A1/A2 rating too as it's the random read/write speeds which should give a similar experience to the onboard memory, especially if you move apps to it.
I've got this one in mine :)
SanDisk Ultra 256 GB microSDXC Memory Card + SD Adapter with A1 App Performance Up to 100 MB/s, Class 10, U1.
Just read you can't use. One drive for pics on a memory card? Is that true? If that's the case there's absolutely no point in me getting one. If you can't back pics up that's not great?
There is a feature which allows s you to sync on drive and Samsung gallery. Ie I pop a pic on one drive on my laptop it appears on my phone. And vice versa.
Without that on a memory card, well, no point in me having a memory card at all
I don't see what the issue is though? Not being able to backup to onedrive is not a fault of the memory card but MS themselves restricting its use for that very purpose. Nothing stopping you from backing up the SD card to PC though and form there you can backup whatever to Onedrive if you want.
I backup a 512GB Micro sd card to PC via USB (Free File Sync app on PC) monthly and that works perfectly.
