Abit IP35 / 2GB - recommended upgrade?
I have an Abit IP35 with Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) CPU and Corsair 2GB DDR2 XMS2-6400C4 TwinX (2x1GB).
I'm currently running Windows XP but want to re-install using Vista Ultimate 64-bit (which I already own), so I would like to upgrade to at least 4GB RAM.
What would you recommend I do (for the least amount of money)? Would I be able to buy something like this to replace my existing memory? Would it be compatible, or should I be considering trying to order another 2 x 1GB identical Corsair modules?
Thanks for any advice!
