Hi everyone
I'm not a gamer but i do need advice on a graphics card please.
I've currently got an Nvidia GeForce GT640 graphics card. I'm very happy with it most of the time, except for when it's trying to convert HD and 4K videos from say mkv to mp4 format, then it takes forever. It does appear to offload some of the conversion to the graphics card as monitoring the GPU in task manager shows the "GPU Video Encode" graph running at 40% but my CPU running at 90% coverting one file (7GB). BTW i use Aimersoft Video converter ultimate for my conversions. I'e already ticked "Enable GPU Acceleration" in the preferences. Note that Aimersoft software supports Radeon AMD, Nvidoa Cuda and Nvidia NVENC for GPU acceleration.
My mothboard is a GA-Z87-HD3 with a intel i7-4770K CPU which again is sufficient for my needs for everything else.
The moterboard has 1 x PCIe x16 running at x16, 1 x PCI Express running at x4 plus 2 x PCI Express x1 slots
I'm after a graphics card for the consumer market (not professional - can't afford that!) that will speed up the conversion of video formats by offloading the majority if not all of the conversion to the graphics card and will fit into my existing hardware.
I'd prefer an nvidia card, but if there isn't one that will do the job, or another make (e.g. AMD) will do the job at a significant cost saving then i'll look at that.
I'd also like the graphics card to have 2 x HDMI outputs as i have two ProLite X2783HSU monitors attached, altough if it's got 1 x HDMI and 1 x DVI then that can work too.
Any help/advice gratefully appreciated
Regards
Ken
Regards
Ken
