Recommended Second Monitor Display!
10 Aug 2016
Saltburn By The Sea
Hello,
Looking for a good second monitor that will work alongside with ASUS ROG Strix XG279Q, Having one screen isn't enough. Aiming at getting IPS screen that's 24inch as it is the second screen, so it be to my left and the main gaming screen in front of me. Rather have IPS for good viewing angles. Doesn't have to be top of the range but something max of £200 and under.
Coincidentally I am also looking for a second monitor which is a 24inch IPS. From initial research you can get a BenQ 24inch IPS monitor which runs at 1920x1080 at 60Hz for £110 and is a nice little monitor. This is a good brand (in my opinion) and my primary display is a 32inch Benq IPS and I am very happy with it. If you want any bells and whistles at all you're paying £150 and upwards for a higher refresh rate - which you probably don't need/want as your primary display is plenty fast enough..
I been looking at the BenQ also since it was a good price, but at the same time looking at Asus so that it will look far better having two Asus on the desk then an odd one you know. But end of the day comes down the price and what's the best.
