Recommended Teamspeak Servers??
12 Feb 2003
Following the collapse of 4u servers, can anyone recommend a decent Teamspeak Server company please? Some friends and I are on the lookout for a new host.
cheers!
Random one if its just you and <4 mates. Otherwise any cheap uk one to be honest, I haven't had any problems with any really.
Well if you want to be cheap do what i did for about a month before i got a new ventrillo server. Only used Teamspeak once so i don't know if its the same. But we just typed in gameservers.com then changed port numbers to random numbers and see if we were lucky and it was empty.
But i use darkstarlic.com or something along those lines. Its the backing for ventrilohosting.com
You could also host your own server if you have reasonable bandwidth.
Its not as hard as you might think if you have an idea about port forwarding on your router. You don't even need a spare box, it'll run quite happily as a service in the background on any decent modern PC, especially for four users.
I use www.totalwebhq.com
They're based in America, but pings are decent (~100), and they're pretty cheap because of $-->£ exchange rate, Im paying about £8/9 a month for a 60man server.
They'll rent you a 10man ts server for about £2 a month :)
