Recommended Voltage for memory ?
Caporegime
8 Sep 2006
On Ocuk
i5 2500k
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU
The memory voltage for the Kingston 8GB is 1.65V when running at it's default xms profile 1600/800mhz. Is this still safe?
Just lower the voltage manually.
The RAM is tested at 1.65V but will usually work at ~1.5V.
You could start at 1.58V and work down from there if it's stable.
