So Im banging my head off the desk....
I had a perfectly set up and working pc, (just built). Then I decided to sort out the cables and tidy the back section of the Air540.
Some of the cables were a bit like a rats nest, so I unconnected, repositioned and reconnected. This included the recon usb connector, (but I put the centre connector back just like it was).
Also the power which was awkward to reconnect and I ended up pushing a couple of pins a little out of the back. They seem to be lined up and back in place now, but I am having problems.
The display on the recon controller is lit, but the fans aren't working anymore.
The controller says its on manual and set to 0000rpm, (i can't seem to adjust it there.). The recon software says manual 100% 12v 200rpm. so....
I uninstalled and reinstalled the software....now there is no info in the software atall. No ip address, no fans shown. sigh. I have turned off the pc and made sure the usb cable was seated okay, (which it seems to be), but still it doesn't see the recon anymore.
BANG...BANG...BANG....
Reinstalled the software as admin and got it back to the 100% 12v 200rpm, no fans working.
The controller says its on manual and set to 0000rpm, (i can't seem to adjust it there.). The recon software says manual 100% 12v 200rpm. so....I uninstalled and reinstalled the software....now there is no info in the software atall. No ip address, no fans shown. sigh. I have turned off the pc and made sure the usb cable was seated okay, (which it seems to be), but still it doesn't see the recon anymore.
