Hey folks,
A friend has shown interest in taking on my old 8700k and most of the parts. There was a power interruption about a year ago, after which it lost it's 5ghz overclock and all the bios settings and I was too lazy to ever properly fix it and just limped on at lower clocks. Before I sell it on, I'm trying to validate that it is still a reliable computer that has some years left in it and not something that's hanging onto life by the skin of its teeth.
It's been sat running y-cruncher for 10 hours overnight @ 4.8 GHz with 1.28 constant vcore. This feels like a nice sane overclock, and I'll run some more tests, but if it continues passing then I think I'm happy to call it good.
But the odd thing is... if I switch to offset voltage, it simply isn't stable in the same way. I've taken it up to the point it hits 1.36v under max load, at only 4.6GHz and it still fails stability tests within 2 hours. It also bumps 90 degrees, which might mean I need to refresh the heat paste! Probably still the same stuff I put in on day one...
Anyway I've varied from -40mv offset with aggressive LLC to +10mv offset with gentle LLC, feeling out where each of them results a vcore near to 1.35, and I cannot get either of them happy, not even at just 4.6GHz.
Is it worth chasing higher offsets, maybe +50mv, with even lower LLC to get the same loaded vcore? If I do that am I at risk of significant voltage spikes under lower loads? And is there some reason it would be inherently less stable with dynamic voltage vs fixed? And is it actually worth it?
Mostly an esoteric technical exercise at this point. In both cases, it will drop to 800MHz at idle, and even with fixed voltage, it's only using about 16 watts when nothing is going on so I'm not sure there is a lot to gain from further tuning - but I would love to understand why it can apparently tolerate a much lower fixed voltage than it can make do with adaptively.
Also be good to know if that trait is a sign of impending system failure! (I have a barely-used Ryzen 1600X+motherboard I could substitute instead so I'd rather make sure I pass on a working computer than one that dies in 6 months.)
Thanks for your thoughts
But at least I've got these bios settings saved safely now, so I can experiment and revert easily.
) - seems solid and stable at 1.3 constant vcore and 4.7GHz. Did a little reading around VCCIO and VCCSA and settled on them as 1.1 and 1.15 respectively. The IO might come down further, the SA appears to be as low as I can get. But either way, this seems very sensible and safe for the long term and I hope it will give years more service at these settings.
