Reconnecting iphone to newly formatted PC
Is your music back on the reformatted drive?
If the music isn't there then when you sync, iTunes will delete the music on your iPhone.
Yes, the contacts and settings data is stored on a different partition in the iPhone.
iTunes might ask you to make a backup when you plug it in, but it will 100% delete your music as it works via sync-only.
