Record cabinet multi use? help
19 Jan 2010
Merseyside
Hi, looking for advice on a cabinet to store my vinyl, have the turntable on top and possibly integrate some bookshelf speakers or is there something that exists thats halfway decent that does this already. Max Dimensions are W100 x D40 x H doesnt matter. Cheers
There are lots of options on Etsy. I got something direct from Lagom Studios but they have a shop on there as well.
Many are 45cm deep but there's probably stuff at 40cm as well, or you could ask if they can make that adjustment as most are made to order.
Kallax are always a safe bet as previously stated, they're my current use however I need to pull the finger out and get something to sit at the back that keeps everything at a nice uniform depth. Hate forgetting you have a record because it's slipped into the ether between two other albums :cry:
