Record from a VGA source?
18 Jan 2007
Land of the Scots
Not sure if this is the right place to put it, but basically I want to be able to record from my Xbox 360 (vga output) any cards out there that will do this?
You can buy an XBOX360 RGB Scart cable for £2.99 if you search around a bit.
edited to add this link XBOX360 RGB/S Video CABLE £2.99 I do not think this is a competitor of OcUK so should be ok. Simpley swap your VGA cable for this when you want to record (must have DVD recorder or S-Video capture card).
