Record From Sleep in WMC
5 Dec 2008
Kent
I couldn't find a more suitable forum so posted here.
I would like to (if possible) record certain shows when I am not at home. Could anyone recommend a simple step-by-step guide or program that would allow me to do this? I would also like for the computer to turn itself off afterwards which I assume can be done in Power Options?
Thanks.
*bump* Hmm, my computer doesn't want to sleep. Well, it does sleep but the computer remains powered on.
It did record something last night. I put it to sleep and everything switched off for a few seconds, then it came back on and was still in a state of sleep (a key press would wake it up). I was hoping that it would save energy (and noise) by sleeping but it's just as loud and colourful as when it's on.
Any advice?
Thanks.
Open a command prompt and use the command Powercfg to track down what is causing the machine to wake, and also if anything is stopping it from sleeping.
"Powercfg -requests" will show you what is stopping the machine from sleeping
"Powercfg -lastwake" shows you what woke the machine up
"Powercfg -help" gives you all the commands, which might be useful when you've tracked down what is causing your issues. E.g. you can use -devicedisablewake to disable certain devices from waking the system.
I seem to get the reply 'You do not have permission to do this' when I try and see what causes this problem.
Sounds like its using S1 sleep, rather than S3.
Theres a nice post here that describes there differences
http://www.crazyengineers.com/community/threads/system-sleep-states-s0-s1-s2-s3-s4-s5.3238/
Thanks. That's all good to know. For some reason it seems to begin in S3 but something happens and it changes to S1.
Try an elevated Command Prompt (run as administrator)
Thank you.
Powercfg -requests returns:
DISPLAY:
None.
SYSTEM:
[DRIVER] High Definition Audio Device (HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_
14627681&REV_1003\4&2f6cd8e8&0&0101)
An audio stream is currently in use.
[DRIVER] \FileSystem\srvnet
An active remote client has recently sent requests to this machine.
[SERVICE] \Device\HarddiskVolume2\Windows\System32\svchost.exe (RasMan)
Active RAS connection
[DRIVER] Legacy Kernel Caller
[PROCESS] \Device\HarddiskVolume2\Windows\ehome\ehshell.exe
AWAYMODE:
None.
If you stop WMC (and all playback) what's left?
I don't know what the Legacy Kernel Caller is. But I do know that the [Driver] \FileSystem\srvnet can be problematic to automatically close down (it's related to network shares) and can remain open even when there is no activity. I disabled it from preventing sleep.
But best bet is to stop all playback, but leave WMC running as if you were putting it to sleep and see what remains in -requests.
Problem Solved. I will put what happened here for future generations.
I typed in a command in command prompt to ignore the driver/process keeping it from sleeping:
Powercfg -requestsoverride DRIVER "High Definition Audio Device" SYSTEM
It worked fine last night.
