Man of Honour
- 15 Mar 2004
- Liverpool
I need a freeware program that does this. With a simply start and stop function, and an easy way to find out where on earth your files are.
greenlizard0 said:Gotta say I'm struggling here - I'm pressing the record button - and then stop - but the files only save as the program's own format - which doesn't even play music back?
iirc to get Audacity to export to something like mp3 you need to download a lame enc.dllgreenlizard0 said:Gotta say I'm struggling here - I'm pressing the record button - and then stop - but the files only save as the program's own format - which doesn't even play music back?
Pho said:Download: http://download.riverpast.com/download/lame3.96.1.zip extract lame_enc.dll to somewhere, i.e. c:\Program Files\Audacity .
MoNkeE said:An even better way would have been by going into Control Panel > Volume Control > Options > Properties > Recording > OK. Then select Stereo Mix and record whatever you want. Just make sure you select Microphone again at the end
-RaZ
i didn't use cables, i captured from the wave instead of line in. no fuss at all just a matter of clicking record and then stop.Chronos-X said:without cables or fuss.
