Recording from a birdbox cam
It's got a 20m cable with a SCART connection, just plug it into the back of your TV and change it to the SCART input then look if your TV supports either outputting that signal somewhere or USB recording. Failing that a cheap DVD recorder would probably be the easiest way then simply rip the video of the DVD to your pc in whatever format you choose.
