Recording Software Audio Problem (Dxtory)
18 May 2011
Hi Guys!
I've just encountered a little problem which worked fine previously before formatting my PC.
I record a lot of games using Dxtory which is an application/game recording software. It allows you to select many audio channels to record, and I usually select a total of two channels, one for my microphone which is connected to my headset, and the other is for my windows default sound device (Realtek high definition audio).
After formatting and installing everything again, I am unable to record any audio with the windows default sound device unless I have it checked as default, in which case I cannot hear anything myself because I use a headset.
I hope this makes sense?
I should be able to record channels 1 (Microphone) & 2 (Realtek HD Audio) while having my headset (GamesCon 780) checked as default device. This is what I had before?
Any help appreciated!
Thanks
