Recovering My Gamertag
26 Oct 2002
East Sussex
Hi Peeps,
Went to recover my gamertag and I keep getting the message that the "Xbox Live Subscription is Unavailable"
The pop displays my gamertag informing me how many friends are online. However the account is not fully recovered :mad:
Anyone had this issue before or knows a fix?
Cheers
Pdog
It does in Half hour!
If I can't renew it via the xbox can I do it another way now?
If you cant renew it using your credit card then youll have to ring ms. I dont know whether or not you can renew using the prepaid subscription cards that you can get off the highstreet?
I'll ring support tomorrow. Nothing else I can do. Thanks for your help Nanoman.
