Hey, just picked up a laptop for my brother for christmas, and its not come with a windows reinstall DVD. Instead, I've just started setting it up (Read: Uninstalling all the junk it came pre-installed with) and its encouraging me to create a 'Factory Default Disc' with an estimated size of 9.16Gb, and will need 3 blank DVDs to burn. Now, this is silly, my Win7 install fitted on one DVD.
So, could I just use a regular windows 7 home premium DVD to reinstall if needed, using the product key on the bottom of the laptop, with no problems? I know with my dell laptop, I always used their CD, and used that to create dell based slipstream SP cds, because I thought there was something fancy on them that meant they activated automatically, not needing you to enter the key during install. But could I forget all that and use an OEM home premium DVD to reinstall if needed?
Thanks!
Thanks!
