Rectangle vs Built in Mac snapping
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
I haven't installed Rectangle on my new Mac yet but am I the only one not liking the built in snapping from the OS as much?
I use Rectangle at work, it seems to snap to the sides easier, it also snaps right to the edge whereas the Mac built in snapping leaves a gap. Also a couple of instances it shoved the window way up the screen where I can't grab the top bar making unable to move the window with the mouse. Having either to close the app completely or using keyboard shortcuts to maximise it and then closing it again.
I've never snapped a window anywhere on any operating system so I'm just going to back out here :D
I open an app/window/whatever, resize it and put it where I want it. Next time I open it, it opens where I left it.
Rectangle is still better but the default OS gets a good load of it
The snapping isn't as good. I just tested now and some instances I need to hold the window there for the overlay to pop up.
Never said it was better or as good just compared to before with nothing and the magic that is rectangle it's much better I still feel any power user will still end up with rectangle or your choice of window manager eventually
Rectangle is definitely better than the built in one, although at least they have something now. macOS is a painful OS for multitasking.
