Recursion using Linked List Java
15 Aug 2010
N. Ireland
Hi all, I am having a bit of trouble with a method to insert a char value in front of a specific char value using recursion.
Here's my recursive and wrapper methods
Code:
     * recursive method for inserting
    public Csc2001Node insertBefore(char c, Csc2001Node head, char toInsert)
        if(head==null){
            return head = new Csc2001Node(toInsert);
        else if (head.next!=null && head.ch == c || head.ch == c)
            Csc2001Node nextNode = head.next;
            head.next = new Csc2001Node(toInsert);
            head.next.next = nextNode;
         else
            head.next = insertBefore (c, head.next, toInsert);
         return head;
     * wrapper method for inserting
    public void insertBefore(char c, char toInsert){
        head = insertBefore(c, head, toInsert);
This is a piece of code from my tester class which adds a character in front of a specific character.
Code:
		System.out.println("Trying to insert V before e into the front of the list and printing out the list");
		mylist.insertBefore('e', 'V');
		mylist.recursePrintList();
The output should be
Trying to insert Z before p, a character that does not exist in the list, and
V e a Y s t e r Z
But my method outputs
Trying to insert Z before p, a character that does not exist in the list, and printing out the list
eVaYsterZ
Notice how the V is outplace by one character.
Anyone shine a light on what Im doing wrong with my recursive method?
Thanks
I have actually been spending half of the day looking through stackoverflow and google :p
Tried implementing a couple of the "solutions" but non have given me the right output for some reason :confused:
What I have is the closest I can get to the correct output.
Isn't this:
Code:
equivalent to this:
Code:
head.ch == c
Also, what I think you want to do is create a new node when that condition is true, and set the "next" pointer of that node to the current head.
Edit: Actually that would disconnect everything before the newly created node.
I think the problem is that you're creating a new node at head.next, when really head should be the next node from your newly created one.
Is the signature of the function fixed? I don't see how this would work, you'd need to know if the node you're visiting is the head, so you know to return a new head when you're adding to the beginning of the list, which is different behavior from inserting anywhere else on the list (where you don't need to return a new head).
You know your university tutors are there for a reason and will help you with this stuff...but anyway, have you not looked at your classmates solution here?
http://stackoverflow.com/questions/...insert-before-method-cutting-off-rest-of-list
