'RECYCLER' folder for second hard drive.
Permabanned
30 Mar 2007
Hi,
I've got a second hard disk installed on my computer at the moment which is D. Now there used to be a folder visible there called "RECYCLER" on the D drive, which seemed to contain everything from the D drive that I deleted, much like the Recycle Bin on the Desktop. But for some reason I can no longer see it, and I cannot see the files in it. I have folder options set to view hidden folders and files.
I can access it by typing "D:/RECYCLER" in the navigation bar but I can see no files inside it. If I look at the folder properties it states there is over 300mb of files in there, which I would like to delete since I don't need them!
Any ideas how I can view/delete these files? Thanks.
