Red Faction Guerilla Steamworks Open Beta! - Huge update with DX11 Support
UPDATE 10th November 2014:
Changelog:
- Experimental DirectX 11 implementation. It replaces DirectX 10 and is disabled by default. To enable it use -nod3d9 command line parameter.
It should fix bugs caused by KB2670838 windows update.
- Added possibility of changing game resolution from the command line. Use -w resx -h resy.
- Fixed not working command line switch to force GFWL save migration (-migrate_live)
- Player Names are displayed correctly in Leaderboards.
- Changed playlist settings. Mode-Min/Max (Anarchy-3/6, Bagman-3/6. Team Anarchy-4/8, Team Bagman-4/8, Team Objective-4/10, Siege-4/12, LargeMixer-4/12)
- Removed XP limitation for all multiplayer game modes.
- Added logs for save migration process. If your save games are not migrating look at save_migration.log file.
Additional notes:
- If error about missing DirectX dlls (for example d3dx_39.dll) appears, you need to install newest DirectX package. After beta it will be included into Steam instalation script.
- For those of you that can not change the game resolution, please update graphics card drivers and delete file DRIVE:\Users\YOUR_USER_NAME\Documents\My Games\Red Faction Guerrilla\Options\rfg_display_options.rfgs_pc
- If you have black screen bug and only hear sounds, please try DX11 mode (-nod3d9 command line parameter)
If the game crashed, a dump file should be created in STEAM\SteamApps\common\Red Faction Guerrilla\build\pc\cache\ folder. It's name looks like rfg_11_07_1_33.dmp.
Sent us those files as they can speed up bug fixing process and please also provide a detailed bug description.
ORIGINAL POST + Instructions
Today I would like to invite you all to participate in the public beta of Red Faction Guerilla with full Steam Support and complete Games for Windows Live Removal.
-) Matchmaking and Multiplayer via Steamworks
-) No Games for Windows Live sign-in required
-) Leaderboards via Steam
-) Voice Chat via Steam
-) Achievements via Steam
-) Uses DX9 Renderer by default as DX10 created a lot of problems and resulted in performance drawbacks (that should also fix Win8 issues)
-) At first launch the game attempts to migrate savegames from GFWL to the new system
To access the beta please do the following:
Follow this guide http://ds.nordicgames.at/SteamBetaBranchGuide.jpg
Under Step 1 select of course the Red Faction Guerilla App
Password for step 4 is: nordicrfgbeta
The branch for Step 6 is named publicbeta
UPDATE 5th November 2014:
Changes:
- The time limit between lobby disconnects is doubled
- Minimum players required to start the team game is four and for normal game it's three.
IMPORTANT:
- The game generates dump files when crash occurs. Dump files are located in the game folder (same as rfg.exe) and thir names are like rfg_*.dmp. Please send it to rfgsupport [~at~] nordicgames.at
http://steamcommunity.com/app/20500/discussions/0/613940477951003365/
Use HTML5 not Flash to get 1080p/60FPS.
Changelog:
Additional notes:
Changes:
IMPORTANT:
