- 21 Jul 2004
- Harrow, UK
What is the red light on the X1900XTX? It isn't always on, but I noticed it come on when I plugged the power into my SATA DVD-RW...
It is the light closest to the power socket, so it would be the one on the right. The card is connected to two molex plugs on different power cables. Since it only came on when the optical drive was plugged back in, I am assuming it is definitely the power.
I think my 450W PSU is struggling with:
Opteron 165 @ 2.7Ghz (no increase in vcore)
2 x 512MB RAM
4 x WD HDDs
1 x DVD-RW
Strange thing is that the card works fine - I was playing UT2004 the other day at maximum settings at 1280x1024 and there was no problem![]()
The one one the left is is a card fault light, the one on the right is an external power problem light.
