Have you got the 24 pin connection plugged into the motherboard? Have you got the 4/8pin connected to the motherboard for the CPU too? Have you also connected the HDDs to the power supply?
The 24 and 8 pin are both connected and the HDD is connected with the larger "L" shaped connection to the PSU and the smaller "L" shaped connected to the mothrboard with the sata 6.
Try pressing the little button next to it. I had to do that the first time I turned mine on with the new Asus board.
No HDD light....have you plugged in the front panel connectors correctly?
I couldnt find the HDDLED socket but read somewhere online that putting it in the IDE LED should work so i put it (and left it) in there.
I think a reason i may have no display is my tv (i cant get my tv in PC mode), ill hopefully be getting a monitor tomorrow.
