RED VS BLUE - No, not Pokémon **WINNERS ANNOUNCED**
22 Aug 2010
***WINNERS***
Congrats to,
Googalaymoogaly is the winner of the Red cooler
thenewoc is the winner of the blue cooler
Please trust message 5UB with your shipping details, thanks all for taking part.
**Ended**
Prolimatech has some of the best coolers on the market, especially for overclocking. We are giving away a RED and BLUE Prolimatech Megahalem cooler to you, simple by replying with your desired colour.
Reply with: Prolimatech Red, I CHOOSE YOU! for Red
Reply with:Prolimatech Blue, I CHOOSE YOU! for Blue
(p.s I love Pokemon)
The competition will run as follows :
- One entry per forum user
- Competition ends Tuesday 21st May @ 12.00pm
- Winners will be randomly selected
- Overclockers UK has full rights to the competition
- OcUK Employees are not allowed to enter
- Competition open to UK residents only
Prolimatech Blue Megahalems CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011) @ £52.99 inc VAT
By popular demand, the ever popular Megahalems now comes in Blue! It has stylish black grainy matte finish for the best looking performance. If looks could kill, this heatsink would reap havoc on any competitor in its path!! Housing this Intimidator is a specially designed package that has every look of a “Collector’s Edition”! Inside the package you get not only one but two sets of fan clips for setting up an awesome arsenal of duo fans. You also get support for installation on any of the Intel's and AMD's recent platforms. Those include Socket 775, 1366,1155/1156, and of course, the newest 2011, and AM2/2+/3/3+. No longer will you have to choose which backplate to use because a specially designed universal backplate has been created for better convenience and better cooling results. What Megahalems has set in performance standards, now Black Megahalems will raise the bar one level higher! Everything else aside, if looks are everything to you, this is the one heatsink to get!!
- Stylish black grainy matte finish for the best looking performance.
- Top fin made of scratch-resistant Stainless Steel to preserve shine.
- Minimal air resistance between fins allowing best balance between noise and performance in range of . - For all out performance, fan RPM at 1600 or above is recommended.
- Heatpipes are lined up in a straight line to prevent air back draft allowing air to easily pass through the heatsink body.
- Wide gaps between fins with mathematically calculated thickness to maximize best air-to-surface cooling rate.
- Easy-to-install retention mechanism for LGA 775, 1366, 1155, 1156 and 2011 and AM2/AM2+/AM3/AM3+.
- Includes easy-to-apply high grade thermal compound, a perfect sidekick to all Prolimatech heatsinks.
- New Universal Backplate to support all Intel platforms.
- Two sets of fan clips for a duo-fan installation
- Heatsink Dimensions: (L)130mm X (W)74mmX (H)158.7mm
- Heatsink Weight: 790 g
- Heatpipes: 6mm X 6pcs
- Suggested Fan: 120mm x 120mm x 25mm or 140mm x 140mm x 25mm
- Suggest Noise Level (dBA): Below 26dBA
- Air Flow: 57 CFM
- Direction of heatsink: Faces the rear exhaust system fan
- CPU Platform: Intel Socket LGA 775/1366/1156/1155/2011 , AMD Socket AM2/2+/3/3+
Only £52.99 inc VAT.
ORDER NOW
Prolimatech Red Megahalems CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011) @ £52.99 inc VAT
By popular demand, the ever popular Megahalems now comes in Red! It has stylish black grainy matte finish for the best looking performance. If looks could kill, this heatsink would reap havoc on any competitor in its path!! Housing this Intimidator is a specially designed package that has every look of a “Collector’s Edition”! Inside the package you get not only one but two sets of fan clips for setting up an awesome arsenal of duo fans. You also get support for installation on any of the Intel's and AMD's recent platforms. Those include Socket 775, 1366,1155/1156, and of course, the newest 2011, and AM2/2+/3/3+. No longer will you have to choose which backplate to use because a specially designed universal backplate has been created for better convenience and better cooling results. What Megahalems has set in performance standards, now Black Megahalems will raise the bar one level higher! Everything else aside, if looks are everything to you, this is the one heatsink to get!!
- Air Flow: 57 CFM
ORDER NOW
