- 27 Feb 2006
- Normanton
I have recently started playing Redalert 1 over LAN against my dad. I still think this is the best strategy game ever made. Its easy, reasonably well balanced and fun.
Sure Starcraft is excellent but it often takes more time to finish a game and its a LOT more complicated. With Redalert (origional, 2 has new pointless fancy units and stupid superpowers) you can build a few structors, take over some ore fields and create a mass army of jets, mammoths, apaches etc. Also some strategic things like tanya, naval attacks...
Easy and fun. If anyone else wants to play LAN Redalert 1 then theres loads of stuff on the net, this site has a lot of stuff listed and help http://www.gametalk.com/talk/pc/command_conquer_red_alert/talk-reply.cgi?id=52672178&fid=g_pcgbbn
But i recommend simply doing this -
(Windows XP Service pack 2)
Install the game from origional cd using win95 compatibility mode
Do not select to restart
Go here http://www.understorm.net/cnc/lan/cnc95_ra1.php/ download the 1.01 final
Extract and copy over the file in the redalert directory, mine is C:\WESTWOOD\REDALERT.
Then go into your network properties
Install - Protocol - IPX - Properties
Set Internal network number on one computer to 10000000
Frame type 802.2
Network number 10000000
Next computer to
00000001
802.2
00000001
Next computer to
00000002
802.2
00000002
Run redalert with CD in or mounted on daemon, alcohol or whatever. You get full working audio and videos. Go to Multiplayer - LAN game and create on one pc and join with another. Use hamache for internet game over LAN.
If you get a timeout error like i did when i had a game you can increase the NWLink IPX timeout from 15minutes to 240mins using command prompt. Unfortunatly i have forgot what i typed and the webpage but i searched for something like NWLink IPX timeout
Frame type 802.2
Next computer to
00000001
802.2
00000001
Next computer to
00000002
802.2
00000002
