Redeclaring or Deleting a Class object
18 Oct 2002
Hi Guys
Hopefully you can help. If I declare a class in PHP like this:
$class = new Class
If I wanted to delete this class how would I do it?
Phil
Just to be pedantic, the variable $class is not a class. It's an object, which is an instance of a class.
Depends what you mean by 'delete'. Just using unset($class) should do.
There are specific magic methods for doing things when you destroy an instance, e.g. unsetting particular properties, running cleanup functions, if that's what you're after.
Yeah i have tried unset but it wont seem to remove it. What I have is this:
white loop {
file is required with class in
functions within that class are executed
Now each time the while is run a different file is required, but within each of the files, I have the same class name. I have tried unset before the while loops to the next round but it still insists that the class has already been declared, even tho I unset it.
I'm not sure I entirely follow what you're doing. it appears the problem is related to the actual class declaration being included more than once, not the instantiation.
Use require_once() or include_once() to ensure the file that contains your class declaration isn't evaluated more than once in the script's execution.
