Redeeming Gears of War 4 on PC
3 May 2011
Leicester
Hoping I'm in the right place for this, just bought a GTX1080 and it's come with Gears 4..... Does anyone know where I type in my redemption code? And also if I redeem it on PC can I still download for Xbox?
Any help given is most appreciated.
Redeem it on your XB1 or open the windows store on your PC, click the icon next to the search bar and you'll see the redeem code option.
Whichever way you do it, it'll be tied to your XBL account and you can download on either/both.
I used an NVidia key that I got off mm, had to go to an NVidia sit, enter code and brings up the login to windows store then they send you the actual game key. When you get the game key, enter it into windows store and download. My Xbox One downloaded the game automatically. I then went into the setting of my windows store account and removed NVidia as they put them self into the bit that lets them access account information and stuff.
