Are all four of the pins definitely pushed in until they click home on the other side of the motherboard?
Does the heatsink actually get warm?
I think all of the pins are in properly, but I haven't physically pushed them to make sure. I'm very new to all this, so I'm not sure how much pressure need be applied to check it.
I haven't touched the heatsink either, so I will put my hand close to it and check that once the computer has been shut down. The problem is I'm back at my parents' house and my pc is in my flat. The reseating is scheduled for Monday! But I'll do the other checks you've just suggested too first.
What kind of case cooling do you have? It doesn't matter how effective your CPU HSF is if the heat it dispels just hangs around in your case.
How many of what sized fans will give us a rough idea of how good it is.
Best,
E-I
I must admit, the cooling isn't extensive! In fact it amounts to:
1) one 80mm exhaust fan
2) while the Intel HSF blows air into a duct and out of a vent in the side of the case.
3) a second perforated vent in the side of the case.
The case hasn't got any intake at the front. And I'm wondering whether the duct actually impedes hot air being removed from the case properly out of the exhaust fan.
My pc consists of the following (to make things clearer I hope):
Intel 6850 + Stock HSF
4x1GB Corsair RAM
2x250GB maxtor HDD
Gainward 4870 1GB 'GS' (has improved cooler)
Arctic 700 PSU
