I'm trying to reduce the noise from my PC. I'll tell you what I have.
Gigabyte P55M-UD2, Intel i5 with Arctic Freezer Pro 7. 8GB RAM
GTX 260 + 7800 GTX (I'm running 3 monitors)
Chieftec Dragon case with 2 x PWM 90mm Artic Cooling fans
OCZ 600w PSU
There is also a soundblaster card, 2 x HDD & 1 x SSD.
First the good stuff.
1) The 90mm Artic cooling fans are excellent, very quiet and push a lot of air. They are PWM controlled by the CPU fan, this is also pretty quite.
Now the bad stuff
1) The 7800 GTX is only used for 2D work and powering my third monitor. However it gets hot, and eventually reaches 80c, this is 2D only. It's sitting directly under the soundblaster, that in turn is directly under the GTX 260, and it's heating everything up above it.
2) The OCZ PSU is not as quite as I would like, not a patch on the Artic cooling fans, and by a mile the loudest part of the system.
3) The Gigabyte P55M-UD2 is a small board, and with 8GB ram it fouls the Artic Freezer Pro 7. The only solution was to turn the cooler around. The fan however will not turn, so i'm blowing air in the opposite direction to case air-flow.
Nothing in the system is overclocked, case temps can reach 50+c after playing games.
Questions?
1) I would like to remove the 7800 GTX. Does anyone know a very good passive cooled Nvidia card to power my third monitor, something that runs cool is the priority.
2) Any recommendations on a quite PSU that can still push some air. Bearing in mind I only have 2 x 90mm fans.
3) Do you think a better option would be to change the case, and ditch the ageing Chieftec Dragon.
4) How bad is the heat trap caused by the CPU cooler turned the wrong way.
I think this is going to get expensive..
Cheers
Jason
OCZ 600w PSU
Now the bad stuff
Questions?
Cheers
Jason
