flying grouse said:check out the monitor from Philips, the new 190X6FB has a "Lightframe digital" which I am led to believe, means you can set the background light, with the press of a button, for different applications.....dvd, games, etc.......
igors said:Other way around is that you simply verify with the manufactures if backlight bleed is covered, as part of the monitor warranty agreement.
Vigil said:It's not bleeding, it's just too bright in general.
ljt said:reduce contrast/brightness/gamma in your graphics card settings, you can set it as dark as you like then
Steves_pc said:apart from the above comments i would have thought changing the gamma settings would have dropped the brightness enough but obviously not to your liking.
Steves_pc said:...a smoked/tinted piece of perspex/acrylic to cover the entire screen and surround would i think be your best bet...
drupi said:Seems a bit strange that you find the 2405FPW too bright. Have you tried reducing color levels to 20-30 ? It has a great impact on brightness. The colors still look great at those levels.
thats the main thing.Vigil said:Sigh. Please read fish99's post.
