So I had an idea in bed at 2am last night.
An idea so great I got up, ran to the office, got my screwdrivers out and immediately tried and tested.
The mesh on the front and top panels of the H440 is held in by screws so can easily be removed, increasing airflow by a fair amount. It comes in 3 pieces, right side of the front panel, left of the top panel and back of the top panel.
I removed all 3 pieces and water temps dropped from about 43C to 37C using my standard BF3 test (where I idle at the spawn menu for hours).
Case won't look as sleek from all angles but I only see it from the left so will test with only that mesh installed and see what difference it makes.
I know a lot of H440 owners struggle with airflow so hopefully this tidbit helps out and if other people can test with their cases that would be cool.
Using 5 Arctic Cooling F12s at 1000rpm on a pair of Alphacool NexXxos ST30 radiators.
