Hi guys,
Been looking around for a set of fans for my new Carbide case and apart from the usual suspects (Gentle Typhoon, Noiseblocker etc) came across the Reeven ColdWing 2000rpm fans.
Was wondering if anyone had any experience of these fans?
Just having a look over and:
2000rpm - 106.7CFM, 36.6dBa
800rpm - 43.03CFM, 14.5dBa
So from the outside they look great if they were installed on a decent fan controller.
From what I can tell the major difference is the sleeve bearing and low MTBF (30000hrs) compared to the majority of other fans (Ball bearing ~150000hrs).
Cheers,
Andy
Cheers,
Andy
but I guess that's personal you might fancy a bit of yellow?
