- 27 Oct 2006
- London
OK I'm no JS coder but yay or nay to this || which version do you prefer ?....
Original code
Revision 2 - No point to this ? {works}
$('.on_off :checkbox').iphoneStyle({ onChange : function () { $('.on_off :checkbox').prop('checked') == false ? socket.emit('updatebart2', false) : socket.emit('updatebart2', true);} });
Revision 3 - Probably the best candidate {works}
$('.on_off :checkbox').iphoneStyle({ onChange : function () { socket.emit('updatebart2', $('.on_off :checkbox').prop('checked'));} });
Revision 4 - Makes obvious sense but the param needs a reference to a function and hence fails {fail}
$('.on_off :checkbox').iphoneStyle({ onChange : socket.emit('updatebart2', $('.on_off :checkbox').prop('checked')) });
Original code
Code:
function myupdatebart2(){
if ($('.on_off :checkbox').prop('checked') == false) {
socket.emit('updatebart2', false);
} else {
$('.on_off :checkbox').iphoneStyle({ onChange : myupdatebart2 });
