- 26 Aug 2010
- West Yorkshire
Okay, i have a reference HIS 6950 that i bought at the end of december. I waited a month or so and i unlocked the shaders on hte card - still working fine. I had the fan set to user define in afterburner to a 1:1 fan speed to temp ratio, and it never went above about 65C on full load, and about 35 idle. Recently i upgraded my motherboard and cpu from a 780 chipset and 695BE to an 890GX chipset and an 1100t. the card worked fine for a day or two and now it is idling at over 50 degrees @50% fan speed which it never did before!
Just wondering what the problem may be. By the end of the year i'm looking to upgrade the cooling to an Arctic Cooling Accelero Xtreme Plus II, so that should col it down and reduce the noise as well, but i's becoming unbearable now as my room, case and GPU are heating up a lot even when no programs are open.
