Hello all. New to OC UK. I bought my last 2 PC's from ************ over the years but was left unsatisfied with both of them, so I hope a PC from here will change that.
I have selected what I think are good components, but some input from those more knowledgeable than I would be greatly appreciated. It is purely for gaming, surfing the web, music...just entertainment. Ok mainly gaming. It may need some refining with my choices. I have £2000 to spend on it.
Case: Bitfenix Colossus Venom
http://www.overclockers.co.uk/showproduct.php?prodid=CA-007-BX
Processor: Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150
http://www.overclockers.co.uk/showproduct.php?prodid=CP-539-IN
Motherboard: Gigabyte Z97X-Gaming 7 Intel Z97 (Socket 1150) DDR3
http://www.overclockers.co.uk/showproduct.php?prodid=MB-491-GI
CPU Cooler: Corsair Hydro H105 Extreme Performance
http://www.overclockers.co.uk/showproduct.php?prodid=HS-025-CS
Memory: Kingston HyperX 16GB (2x8GB) PC3-19200C11 2400MHz
http://www.overclockers.co.uk/showproduct.php?prodid=MY-182-KS
G-Card: Gigabyte GeForce GTX 980 "Reference Design" 4096MB
http://www.overclockers.co.uk/showproduct.php?prodid=GX-146-GI
1st HDD: Samsung 500GB SSD 840 EVO SATA 6Gb/s
http://www.overclockers.co.uk/showproduct.php?prodid=HD-169-SA
2nd HDD: Seagate Barracuda 2TB 7200RPM SATA 6Gb/s
http://www.overclockers.co.uk/showproduct.php?prodid=HD-255-SE
Optical Drive: OcUK Value Blu-ray / DVDRW
http://www.overclockers.co.uk/showproduct.php?prodid=CD-004-OK
Sound Card: Creative Sound Blaster Z High Performance Gaming Sound Card
http://www.overclockers.co.uk/showproduct.php?prodid=SC-087-CL
Power Supply: Corsair RM Series RM 850 '80+ Gold' 850W Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-155-CS
_____________________________________________
Think that's the main things. But...
1, is 16gb memory overkill? I don't think I've come across anything for gaming that used that much. Though for future proofing...
2, I've seen better nVidia 980's than the ones you select in system configurator, but they're not on the list of choices. Can you somehow select a better one. Or is a few more clock mhz even worth it.
3, is the PSU too much or too little.
The whole thing comes to £1, 908. I'd rather not go over but I could do. I don't need mouse or keyboard, monitor or sound systems. I already have those.
Thank you very much for any replies.
