12 Jun 2006 at 18:42 #1 Mr Men Mr Men Soldato Joined 5 May 2006 Posts 9,203 Location PSN I need to remove my heatsink to replace the psu, will I need to clean and re-apply thermal compound or is it ok just to put the hs back on as it is?
12 Jun 2006 at 19:17 #2 Stelly Stelly Don Joined 5 Oct 2005 Posts 11,302 Location Liverpool Mr Men said: I need to remove my heatsink to replace the psu, will I need to clean and re-apply thermal compound or is it ok just to put the hs back on as it is? Click to expand... If there is not that much paste on there put a little on... always an idea to clean you CPU and heat sink once and a while, now seems like a good idea Stelly
