- 17 Sep 2006
- Gloucestershire
I had to reformat my PC, and so I had to reload my itunes library. Ive done this before without a problem, as I backup my iTunes music folder (with my library and xml files etc).
When I reload windows, I put this backup folder back into the default music folder, so when I start iTunes it read the library as before. (I keep all my music on another HDD, so my files havent changed after format)
BUT, when I load iTunes it says the library file is not a valid library! It has attempted to recover the library and renamed it Library (damaged)
Why is it doing this? Surely nothing has changed from before and after the format as the iTunes folder is EXACTLY the same?
Any help on this would be much appreciated!
