reformat with no net connection
19 May 2004
my work pc isnt connected to the net, if i remember right there was a file you could copy and place back into a fresh install so you dont have to reactivate, is this true and does anyone know which 1 it is if so.
you can backup the file
and restore it to same the location after setup is complete - providing the hardware hasn't been changed then it should work fine. as the file is locked to each invidual pc hardware configuration, i can't see there being a problem with this? :)
edited: see below.... :p
