Refresh on wide screen
30 Aug 2006
What kind of refresh rate can you get on a widescreen LCD? Ive only seen specs with 60Hz (At prices below £160) Can you get better rates at the max res?
60Hz is always the recommended refresh rate for a TFT. Some will support 75hz as a maximum, but not always over DVI.
Thanks for the reply.
Does a wide screen monitor give a 'normal' picture. i.e. When playing games is the picture streached at all? Do you have to have special wide screen games?
Most newer games have Widescreen resolutions ready to pick, so its as easy as going into the options
Some older games you can simply change the .ini or .cfg file to change the resolution manually
For info on how to get pretty much any game ever made into widescreen, go here: Widescreen Gaming Forum
And Widescreen gaming is awesome, you'll never want to use a 4:3 monitor again
Hmmm - very informative thread - was just asking the questions that this answers in another thread - everyone seems to give WS a go over 4:3
