http://www.iiyama.co.uk/default.asp?SID=&LNG=EN&NAV=236&PCAT=1&PROD=2297&CE=F&PARAMS=DATASHEET
Have that monitor but it doesnt seem to support the rates reported on the site
for example i use a little app called REforce if i set the specified rates
they disappear ie meaning it isnt supported if i add 1024-768 118 hz
as stated in the tech specs 1024 disappears from my selectable resolutions
are the tech specs wrong as the correct hz seems to be 85 hz for 1024 mode.
I have installed the official drivers and the same happens with default plug n play xp monitor drivers.
