Hi,
As you guys a probably aware there has recently been a few products launched in the graphics card and motherboard range. Due to the new releases we have done a little refresh on our water cooled tech labs items that are designed to take the hassle of adding a water block yourself.
The blocks are all added by our professional technical team so you have peace of mind that they are done correctly.
We have decided to do the range a little different this time to let you guys know exactly what you are getting rather than the normal generic option which is usually just the OcUK branded card.
So below are a few that we have listed online but in total we currently have 25 graphics card options and 22 motherboard options to choose from.
The range has never been so big and hopefully you will be able to find the card you want in the list and we can help with the fitting of the water block.
All the 1080 Cards listed below are also available as a 1070 options as well.
Asus Geforce GTX 1080 FE Water Cooled Graphics Card @ £661.99 inc VAT https://www.overclockers.co.uk/asus-geforce-gtx-1080-fe-water-cooled-graphics-card-wc-14j-tl.html
EK-FC1080 GTX is a high performance full-cover water block for nVidia Founders Edition design GeForce GTX 1080 series graphics cards.
Only £661.99 inc VAT.
ORDER NOW
MSI Geforce GTX 1080 FE Water Cooled Graphics Card @ £647.99 inc VAT https://www.overclockers.co.uk/msi-geforce-gtx-1080-fe-water-cooled-graphics-card-wc-14m-tl.html
Only £647.99 inc VAT.
ORDER NOW
EVGA Geforce GTX 1080 FE Water Cooled Graphics Card @ £647.99 inc VAT https://www.overclockers.co.uk/evga-geforce-gtx-1080-fe-water-cooled-graphics-card-wc-14k-tl.html
ORDER NOW
EVGA Geforce GTX 1080 SC Gaming ACX 3.0 Water Cooled Graphics Card @ £643.99 inc VAT https://www.overclockers.co.uk/evga...3.0-water-cooled-graphics-card-wc-14t-tl.html
EK-FC1080 GTX is a high performance full-cover water block for nVidia GeForce GTX 1080 series graphics cards.
Only £643.99 inc VAT.
ORDER NOW
Asus GeForce GTX 1080 OC Strix Gaming Water Cooled Graphics Card @ £707.99 inc VAT https://www.overclockers.co.uk/asus...ing-water-cooled-graphics-card-wc-14n-tl.html
EK-FC1080 GTX Strix is a high performance full-cover water block for nVidia strix design GeForce GTX 1080 series graphics cards.
Only £707.99 inc VAT.
ORDER NOW
MSI GeForce GTX 1080 Gaming X 8GB Water Cooled Graphics Card @ £691.99 inc VAT https://www.overclockers.co.uk/msi-...8gb-water-cooled-graphics-card-wc-14v-tl.html
EK-FC1080 GTX TF6 is a high performance full-cover water block for nVidia MSI Gaming X GeForce GTX 1080 and 1070 series graphics cards.
Only £691.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 1080 G1 Gaming Water Cooled Graphics Card @ £667.99 inc VAT https://www.overclockers.co.uk/giga...ing-water-cooled-graphics-card-wc-14z-tl.html
EK-FC1080 GTX G1 is a high performance full-cover water block for nVidia Gigabyte G1 Gaming GeForce GTX 1080 and 1070 series graphics cards.
Only £667.99 inc VAT.
ORDER NOW
OcUK Tech Labs - Asus X99-A II Motherboard - EKWB Acetal Water Block @ £335.99 inc VAT https://www.overclockers.co.uk/ocuk...rboard-ekwb-acetal-water-block-wc-961-ek.html
Socket 2011-3, Intel X99 Chipset, 3x PCI-E 3.0 x16, 2x PCI-E x1, 10x SATA 6Gb/s, SATA Express, M.2 Slot, 2x USB3.1, 8x USB3.0 - Custom Cooled with EK Water Blocks Monoblock Watercooling Solution.
Only £335.99 inc VAT.
ORDER NOW
OcUK Tech Labs - Asus X99 Deluxe II Motherboard - EKWB Acetal Water Block @ £467.99 inc VAT https://www.overclockers.co.uk/ocuk...rboard-ekwb-acetal-water-block-wc-963-ek.html
Socket 2011-3, Intel X99 Chipset, 5x PCI-E 3.0 x16, 1x PCI-E x1, 12x SATA 6Gb/s, SATA Express, M.2 Slot, 14x USB 3.0, 6x USB 2.0, - Custom Cooled with EK Water Blocks Monoblock Watercooling Solution.
Only £467.99 inc VAT.
ORDER NOW
OcUK Tech Labs Asus Z170 Sabertooth Mark S Watercooled with EK Waterblocks @ £274.99 inc VAT https://www.overclockers.co.uk/ocuk...atercooled-with-ek-waterblocks-wc-14d-tl.html
Skylake 6th Gen, DDR4, 3x PCIE x16, 3x PCIE x1, 8x SATA 6Gb/s, SATA-Express, M.2 (SATA/PCIE), Gigabit LAN, 7.1 HD Audio, 1x USB3.1, 6x USB3.0, 8x USB2.0, 1x 5Gb/s USB Type C, Crossfire/SLI
Only £274.99 inc VAT.
ORDER NOW
OcUK Tech Labs - Asus Strix X99 Gaming Motherboard - EKWB Acetal Water Block @ £377.99 inc VAT https://www.overclockers.co.uk/ocuk...rboard-ekwb-acetal-water-block-wc-14e-tl.html
6th generation Intel Extreme "Broadwell-E" Processor support, DDR4 3333(OC) Support, Triple GPU Support, SATA Express, M.2 NVMe, U.2, 8x SATA, 4x USB3.1, 8x USB 3.0, 8x USB 2.0, 2x Gigabit LAN, WIFIAC
Only £377.99 inc VAT.
ORDER NOW
1070 Tech Labs Cards Also Available Here
480 Tech Labs Cards Also Available Here
You can view our entire water cooled Graphics Card range here
You can view our entire water cooled Motherboard range here
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
