Hi.
I have a backup PC, which is several years old but still "okay". I'm away to build myself a new main one so my current main will be my new backup and I want to refresh the old backup for my friend's kids. They're console kiddies so are used to a decent level of graphics but have never had a full PC... bearing that in mind, what should I do with the following -
Motherboard - EVGA nForce 780i SLI
CPU - Intel Core 2 Duo E8400 @ 3Ghz Wolfdale
Memory - 4 x 1Gb DDR2
GPU - 1024Mb Radeon HD5870
PSU - Zalman ZH600-SE
Case, fans, CPU cooler, DVD-RW are all good and will be reused. New HD will be added.
If I wanted to spend £200 - £350 giving it a bit of a boost, what would you recommend? I'm thinking maybe CPU, Mobo and RAM - the GPU is okay I feel. But what would be the best bang for buck in the price range I have and would it be worth doing, or just stick with what I have?
Thanks in advance.
Thanks in advance.
