- 28 Oct 2011
Was fine until a few days ago, bought in October.
Anyone have any ideas?
Firmware upgrade?
Have one myself. No problems so far... kinda worried now, though.
Try using Corsair Link 2 and see if you have any control over that. I use link for my H100i and FanXpert2 for my case fans, works perfectly
Note: If you are using Windows 8/8.1, you will need to edit the registry to see the H100 fans & pump in Link.
Yeah, mine doesn't either.
Can you see your H100i in Link?
If you can, select the fan on the left and on the right set a profile. Not sure if it would help, but you get some form of control!
Refirb unit?
H100 or H100i? Seems a bit of confusion in this thread.
Corsair Link software won't see a H100 unless it's connected through something like the Link Commander. Also if it IS the H100, double check the bios for fan speed control, turn it off for whatever header you're using for the pump.
If it's the H100i you may be running firmware that's too early for the CL software to 'see' it. Try updating the firmware with an earlier version of the CL software.
*edit*
Saw your thread on the Corsair forums. We'll try and get you sorted here cos there's a lot of angry opinions over there to get in the way of a resolution.
Corsair Link will only work if you have the 'i' models. Sorry!
Is it the motherboard in your sig? If it is I'll pull the info for you.
